1300
Issue with the @(Html.Infragistics().Grid)
Ihave one issue regarding @(Html.Infragistics().Grid).
The details are given below.
First of all I have taken a grid inside a div.
and calling like below. so data is displaying and everything is working fine.
<div id="igGridLoanPipeline" class="pipeline_content">
<div id="divNewPipeline">
@(Html.Infragistics().Grid<LoneOakOrigination.Domain.CustomEntities.LoanPipeline>()
.ID("igGridPipeline")
.AutoGenerateColumns(false)
.PrimaryKey("PKLoanID")
.RenderCheckboxes(true)
.Virtualization(false)
.ShowHeader(true)
.FixedHeaders(true)
.Columns(column =>
column.For(x => x.Active).DataType("bool").HeaderText("Active").Width("50px");
column.For(x => x.FriendlyLoanID).DataType("string").HeaderText("ID").Width("80px");
column.For(x => x.LoanName).DataType("string").HeaderText("Loan Name").Width("140px");
column.For(x => x.Address).DataType("string").HeaderText("Address").Width("150px");
column.For(x => x.PropertyType).DataType("string").HeaderText("Property Type").Width("105px");
column.For(x => x.LoanAmount).DataType("string").HeaderText("Loan Amount").Width("130px").Format("currency");
column.For(x => x.TotalLTV).DataType("string").HeaderText("LTV").Width("65px");
column.For(x => x.PrimaryContact).DataType("string").HeaderText("Primary Contact").Width("130px");
column.For(x => x.TransactionType).DataType("string").HeaderText("Transaction Type").Width("125px");
column.For(x => x.Status).DataType("string").HeaderText("Status").Width("90px");
column.For(x => x.LoanOfficer).DataType("string").HeaderText("Loan Officer").Width("110px");
column.For(x => x.UpdatedOn).DataType("date").HeaderText("Date Modified").Format("MM/dd/yyyy").Width("110px");
column.For(x => x.PKLoanID).DataType("number").HeaderText("ID").Hidden(true);
.Features(features =>
features.Filtering();
features.Paging().PageSize(50).ShowPageSizeDropDown(true).PageSizeDropDownLabel("Show").PageSizeDropDownTrailingLabel("records").PageSizeDropDownLocation("above").ShowPagerRecordsLabel(true).PrevPageLabelText("Previous").NextPageLabelText("NEXT").VisiblePageCount(5);
features.Sorting().Mode(SortingMode.Single).ColumnSettings(settings =>
//{ columnKey: "UpdatedOn", allowSorting: true, firstSortDirection: "ascending", currentSortDirection: "descending" },
settings.ColumnSetting().ColumnKey("UpdatedOn").AllowSorting(true).FirstSortDirection("ascending").CurrentSortDirection("descending");
features.Selection().MouseDragSelect(true).MultipleSelection(false).Mode(SelectionMode.Row).MultipleCellSelectOnClick(false);
features.Resizing();
.ClientDataSourceType(ClientDataSourceType.JSON)
.DataSourceUrl(Url.Action("PipeLineGridData", "Home"))
.LoadOnDemand(true)
.Height("600")
.LocalSchemaTransform(false)
.DataBind()
.Render()
</div>
Then I have a search textbox with search input button.
Based on searh option I need to display filtered data in the above grid.
But I am unable to bind it to the above grid.
As the grid is not rendering perfectly and losing features of paging and filtering.
So, can you please suggest me how to solve this above issue.
How to rebind the above grid in a search button.
Thanks and Regards,
sree
  • 4315
    Hi, Shahin.
    Thank you for the patience. I have a solution that I hope will help you resolve your case. It doesn't depend on if you want to search on the client or on the server. The solution uses the igGrid filtering API and therefore the grid will do the filtering internally and depending on the configuration it will be on the server or on the client. When you click the link that I've sent you, on the "Methods" tab, the "filter" method can be found. It simulates the filtering the same way as it can be done from the igGrid UI.
    If what you want to achieve is to search for a certain value in entire grid, this means that you want to search all the columns for that value. Therefor if you filter all the columns by that value you will filter the grid. The "filter" method allows you to do exactly this - as an array you can list the filter conditions you want. Let's say the word we want to search is "geek". The code below can do the filtering:
    $("#grid1").igGridFiltering("filter", [
                    { fieldName: "Name", cond: "contains", expr: "geek", logic: "OR" },
                    { fieldName: "ProductNumber", cond: "contains", expr: "geek", logic: "OR" }  ], true); });
    Notice that the "logic" is OR in all the conditions and that's in order to return a result if it is available at least at one of the grid columns. If the grid column is of type number this means that the "expr" should be also from type number.
    I hope this you help you, but if you have further questions, don't hesitate to ask them.
    Best regards,
    Nikolay Alipiev
  • 4315
    Hi, Shahin.
    Thank you for using our product and I will be glad if I can help you.
    I will need additional information regarding your scenario and I will be glad if you can give it to me. In order to direct my efforts on the right direction I need to know where you are doing the filtering of the data on the client or on the server? Are only rendering the grid using the MVC wrapper and then you are doing the filtering on the client, or you want your Search button to trigger a postback and then on the server to filter and send the new data to the igGrid. Thank you in advance!
    Best regards,
    Nikolay Alipiev
