455
Feature Chooser not showing - div not created
This is a simplification of a previous post.
I have 2 projects/solutions using very similar code to generate an iggrid. One creates HTML which contains DIVs holding the featurechoosericon, the other doesn't. I have checked js and css references and can't see any issues. See below
The following
    @(Html.Infragistics().Grid(Model.Customers.AsQueryable()).PrimaryKey(
"ID")
        .Features(features =>
            features.Hiding().ColumnChooserHideOnClick(true);
            features.Sorting().ModalDialogSortOnClick(false).Mode(SortingMode.Multiple).Type(OpType.Local);
//features.Resizing();
            features.Paging().PageSize(10).Type(OpType.Local);
            features.Filtering();
            features.Updating();
                        .ID("GraphGrid")
                        .Width("100%")
                        .Height("500px")
                        .DataBind()
        .Render()
generates table cells as follows
<th title="click to sort column" class="ui-iggrid-header ui-widget-header ui-iggrid-sortableheader ui-state-default"  id="GraphGrid_ID">
<a href="#">
<span class="ui-iggrid-headertext">ID</span>
 <span class="ui-iggrid-colindicator"></span>
</a>
 <div class="ui-iggrid-indicatorcontainer">
        <a title="" id="GraphGrid_featureChooser_headerButton_ID" href="#" th-remove-focus="">
  <span class="ui-iggrid-featurechooserbutton ui-icon ui-icon-gear"></span>
  </a>
    </div>
 </th>
This
@(Html.Infragistics().Grid<System.Data.DataTable>(Model)
 .PrimaryKey("Datagain file:")
   .Features(features =>     {
  features.Updating();     })
 .ID("GraphGrid")
 .DataSource(Model)
.DataBind()
.Render())
creates HTML without the divs for the feature chooser.
<th title="click to sort column" class="ui-iggrid-header ui-widget-header ui-iggrid-sortableheader ui-state-default" id="GraphGrid_Datagain file:">
 <a href="#">
 <span class="ui-iggrid-headertext">Datagain file:</span>
</a>
 </th>.
