1145
Documentation corrections
First of all, please don't take this as a complaint about the documentation. The work I'm currently doing has required me to go through the Options documentation for igGrid (as well as some of the features) and igCombo.
I came across a number of errors and inconsistencies which are enumerated below. If I'm incorrect about any of these, please reply and let me know as it directly effects the work I'm currently doing. For now I'm going with the assumption that my corrections are correct.
igGrid - Options
adjustVirtualHeights - Type: enumeration, should be bool
caption - Default: null, should be ""
columns -> dataType - Marked as enumeration, but allowed values aren't listed.
defaultColumnWidth - Default: null (null isn't specified as one of the enumerated types)
primaryKey - Defualt: null, should be ""
virtualizationMouseWheelStep - Default: null inconsistent with Type: number
igGridFiltering - Options
advancedModeEditorsVisible - Type: enumeration, should be bool
caseSensitive - Type: enumeration, should be bool
filterSummaryAlwaysVisible - Type: enumeration, should be bool
labels - All the items under labels are marked with a type of object, but should be string
mode - Default: null (null isn't specified as one of the enumerated types)
nulls - Same issue as labels
renderFC - Type: enumeration, should be bool
renderFilterButton - Type: enumeration, should be bool
showEmptyConditions - Type: enumeration, should be bool
showNullConditions - Type: enumeration, should be bool
type - Default: null (null isn't specified as one of the enumerated types)
igGridPaging - Options
defaultDropDownWidth - Type: number - Probably not a documentation issue, but inconsistent with widths specified elsewhere which are enumerations with string and number
pageSizeList - Elements Type: object, should be number
pageSizeUrl - Default: null, should be ""
recordCountKey - Default: null, should be ""
igGridSorting - Options
applySortedColumnCss - Type: enumeration, should be bool
columnSettings - Every columnSetting (except allowSorting) is listed with a default of null, and none are objects or enumerations with null listed as a valid value.
modalDialogGHeight - Type: number Default: ""
sortUrlKey, sortUrlKeyAscValue, sortUrlKeyDescValue - Type: string, but all have a default of null
