HI,
I have tried to use the example provided in
https://ko.infragistics.com/community/forums/f/ignite-ui-for-javascript/77099/remote-paging/389378#389378
but it does not work. The grid shows 25 rows so I know that its hitting the customGridPaging element but it still only shows 1 page and a total of 25 records, when i set the customtotalrecordcount to 1000. And when i put a breakpoint in the
TransformDataSource method, it does not get hit
Here is my front end grid:
@(Html.Infragistics().Grid<UsersViewModel>() .ID("grid1") .AutoGenerateColumns(false) .Columns(col => { col.For(x => x.FullName).DataType("string").HeaderText("Name").Width("200"); col.For(x => x.ManagerName).DataType("string").HeaderText("Manager").Width("150"); col.For(x => x.ApprovingManagerName).DataType("string").HeaderText("Approving Manager").Width("150"); col.For(x => x.Email).DataType("string").HeaderText("Email").Width("150"); col.For(x => x.LastLoginDateString).DataType("string").HeaderText("Last Login").Width("150"); }) .Features(features => { features.Selection().Mode(SelectionMode.Row); features.Filtering().Type(OpType.Local); features.Sorting().Type(OpType.Local); features.Features.Add(new CustomGridPaging() { Type = OpType.Remote, PageSize = 25, CustomTotalRecordsCount =1000 }); }) .RowTemplate("<tr><td>${FullName}</td><td>${ManagerName}</td><td>${ApprovingManagerName}</td><td>${Email}</td><td>${LastLoginDateString}</td></tr>") .DataSourceUrl(Url.Action("BindGrid")) .PrimaryKey("ID") .DataBind() .Render())
Here is the customgridpaging file:
public class CustomGridPaging : GridPaging { public int CustomTotalRecordsCount { get; set; } public override void TransformDataSource(NameValueCollection queryString, IGridModel grid, out IQueryable queryable) { queryable = (IQueryable)grid.DataSource; this.TotalRecordsCount = this.CustomTotalRecordsCount; } }
Here is the controller action method:
[GridDataSourceAction] public ActionResult BindGrid(int page, int pageSize)
{ int startRow = (page - 1) * pageSize; PortalList<User> userData = SecurityService.GetUserList(startRow, pageSize); ViewBag.TotalRecords = userData.TotalRows; var userDataList = userData.List; Mapper.CreateMap<User, UsersViewModel>(); var usersViewModel = Mapper.Map<List<User>, List<UsersViewModel>>(userDataList); return View("InfragTest", usersViewModel.AsQueryable()); }
public ActionResult InfragTest() { return View(); }
Hello Doug,
I am just following up to see if you need any further assistance with this matter.
Hi Doug,
The custom paging solution which I provided in the forum post you refer to (http://ko.infragistics.com/community/forums/p/77099/389378.aspx#389378) works only when you initialize the grid model in the controller using the GridModel class. The reason is that the chaining configuration is stateless i.e. it is executed only once when the View is created, thus the configuration cannot be recreated when an action method decorated with GridDataSourceAction attribute is executed.
In fact GridDataSourceAction attribute creates a GridModel instance automatically behind the scenes. To do this it parses the query string and tries to guess which features are initialized by the grid, so it can include them in the GridModel instance. However it only initializes the feature classes provided in the Infragistics.Web.Mvc.dll, which means that it cannot initialize your custom class. That's why your breakpoint is not hit.
Please, use the sample I provided in order to see how to configure the custom grid paging in controller.
Hope this helps,Martin PavlovInfragistics, Inc.
