60
Memory leakage in igGrid (IE only)
Problem: Memory leakage in igGrid (IE only)
Description:
We are currently using igGrid throughout our application, we are running into a likely memory leakage issue with the igGrid component of the Infragisitcs jQuery Controls.
How to test:
  1. Create a dummy page with an igGrid  Control, bind it to a remote data source
  2. Open task manager and monitor the memory usage
  3. Refresh the screen and monitor the memory usage of the process
  4. Repeat step 4 and see the memory usage climb
  5. Once the memory usage reaches a limit on the client side, the page crashes and the grids are not rendered properly, the browser crashes and the application has to be restarted to render the page correctly.
