i am able to display images in ig combo using item template but when selecting any item from combo box it displaying path of image instead of image .So how to display selected combo item as image .my application in mvc .please provide sample code
Hello shahinkohan,
Thank you for the update.
At the moment, our igCombo's display or editing field uses <input type=text>. In way it is not a container and is not able to show an image.
After consulting with our developers, there is a possible workaround. We may insert a custom html element with absolute position into an existing layout of the igCombo. This way the element/image may appear on top of the Input. As a side effect, it may cover all possible text. And this may be for display purpose, since this may interfere with the igCombo's functionality.
If you have any questions, please let me know as well.
please provide solution on this ,it is very urgent for me
Gopi.T
At the moment, I am setting up a sample to reproduce the behavior. I will have details for you on or before Friday.
