In my ig grid there are 3 check boxes in each row and user can check any one check box from them but only one check box should be checked at a time in a row . i.e., Need to uncheck previous check boxes except the current clicked one.
please try to provide me solution for implementing the above criteria.
Hello Shahinkohan,
Hello Shahin,
shahinkohan said:1)click on 3rd row then click on 2nd row .when we click on 2nd row previous state of radio button not loading in fist column (radio button is checked but not showing edit mode)
You can use the following code in order to fix the issue:
function radioFormatter(val) {
return "<input type='radio' "+ (val === true ? "checked='checked'" : '') +" style='width:100%; margin: 0px;' readonly='readonly' onclick='this.checked = false;'/>";
shahinkohan said:2)when we adding new row it is going to bottom of grid .is there any way to show new records at top of grid with out refreshing page or reloading
This is by design. Unfortunately you should reload the data and sort by some criteria it in order to get the newly added rows on the top. Of course you can manually manipulate the DOM and move the last row on the top of the grid, but you should take into account the zebra styles of the rows.
Hope this helps,Martin PavlovInfragistics, Inc.
Hello shahinkohan,
Thank you for the update and sample.
We may have to handle the input.click event and change the input attribute depending on the current state of the input as follows:
input.click(function (ui, evt)
var checked = input.attr("checked");
if (input.is(":checked")) {
input.attr("checked", false);
else {
input.attr("checked", true);
updating._notifyChanged();
If you have any questions, please let me know as well.
Hello Martin,
please provide some solution on above issues ,it is very urgent for me .
Gopi.T
i tired with your sample code but i got one more issue please check following scenario in attached file
Best regards,
Gopi
