I use your Ignite UI Starter MVC 4 (Razor) project and I encounter a problem with the '\' sign into TextEditors: This sign not appear if I use @Html.Infragistics().TextEditorFor().
Based on your template for en new project, this is what I do :
In Index.cshtml, I add a TextEditorFor => @Html.Infragistics().TextEditorFor(m => m.Customers.First().Name).Render()
In HomeController.cs, I add the '\' for the customer John Smith => new Customer { ID=1, Name="John\\Smith", IsActive=true },
On runtime, the Grid shows "John\Smith" but the TextEditor shows "JohnSmith".
What I'm doing wrong ?
Thanks in advance for your repply.
Maxime DRIVET.
Hi Maxime,
Thank you for report. That issue has been fixed and updates will be available within service releases.
