Hi,I am trying to change the defaultValue of an igGrid column. The first default value was set during GridModel definition (on the controller side). After a user click I have to change it in another value.I tried this one:
var columnSettings = $("#grid_id").igGridUpdating("option", "columnSettings");alert(columnSettings[1].defaultValue);
And I can see the right first default value. But if I try to do:
var columnSettings = $("#grid_id").igGridUpdating("option", "columnSettings");columnSettings[1].defaultValue = 12345;
Nothing happened...Or better: if I print (javascript alert) all the column settings I can see the default value of that column changed to the new one, but when I add a new row, the default value of that column still starts as 0 (the very first default value).
Why?
Flavio M.
Hi Martin,
Greang a sample project for you when I found the problem. The column of which I was trying to set the default value was a readonly one. I thought that, through javascript, it was possible also to edit a readonly field, but probably I was wrong, beacuse in the sample project I did not put a readonly condition and everything worked right. Of course I tested the same on my actual project and everything works also there.
Sorry for the time you dedicated to this...
PS Anyway, my actual IgniteUI version is 2013.1 2039
Hello Flavio,Your code looks fine. I wasn't able to reproduce this issue. What version (including build) of Ignite UI are you using?A sample will be very helpful.Best regards,Martin PavlovInfragistics, Inc.
