in this post http://ko.infragistics.com/community/forums/t/75037.aspx, on the 10-29-2012 I asked about events to be caught in order to know when user clikced on OK, Cancel or Close button of a RowEditTemplate dialog.It was IgniteUI 2012.2.
Now I re-ask, is there a better way than this one:
$("#grid_one").live('iggridupdatingroweditdialogclosed', function (event, ui) { if (event.buttons == 0) { // Ok button $("#grid_one").igGrid("saveChanges"); } });
to catch user click buttons in IgniteUI 2013.1? Also because now I need to understand when user clicks OK button and when Close button...All these is because calssic iggridupdatingeditrowended is not caught whe RowEditTemplate is enable...
Flavio M.
I am attempting to do the same thing and that is capture what button was pressed on the Dialog closed. but it seems that it is working. I have version 14.2 so this may not work the same?
The goal is that once the user presses the "Done" button. I create a new empty row. Any help on that would be appreciated also.
thanks
Yeah, you're right!
This works, even if I have to pay attention to the used language. "Done" if I use the English version, "Fatto" if I use the Italian one and so on...
But this is another point, localization one ;-)
Thank you Martin!!
Hello Flavio,
In my sample I defined the event inline in the grid initialization. For the delegate event handler try using the following code:var $button = $(e.originalEvent.currentTarget).data("igButton");
The change is needed because of the event bubbling mechanism.
Best regards,Martin PavlovInfragistics, Inc.
Hi Martin,
thanks. I think your implementation is much more clear than mine. I would like to implement it, but I am not able...Is this right?
$(document).delegate("#grid_1", "iggridupdatingroweditdialogclosed", function (e, args) { var $button = $(e.currentTarget).data("igButton"); //Done or Cancel buttons clicked if ($button) { var buttonCaption = $button.options.labelText; if (buttonCaption === "Done") { alert("DONE"); } } else { alert("CANCEL o X"); } });
I tried to debug it, but I can see only undefined on the $button var...while I am able to see $(e.currentTarget).data("igGrid").What am I doing wrong?
Currently there is no straightforward way to determine which button is clicked. However I can provide you with the following solution:
rowEditDialogClosed: function (event, ui) { var $button = $(event.currentTarget).data("igButton"); //Done or Cancel buttons clicked if ($button) { var buttonCaption = $button.options.labelText; if (buttonCaption === "Done") { $("#grid_one").igGrid("saveChanges"); } } else { // Esc button pressed or X button clicked }}
