I have created the Ignite Grid using MVC Wrapper. I have given the datasource url as following:
DataSourceUrl(Url.Action("GetPagedUsers", "User"))
So, when the page (which contains the Grid) loads the Grid automatically sends a request to this url. I need to prevent the Grid from automatically requesting the server for data when the page loads.
I have tried a workaround for this: return false from the event "iggriddatabinding", but then the Grid never shows.
Any ideas how to achieve this?
Arfan Baig
Hi Arfan,
In that case you can hook to the dataBinding grid event, and cancel it if your condition is not met. this will cancel any requests & rendering of data.
You can have a look here for more details:
http://help.infragistics.com/jQuery/2013.1/ui.iggrid => Events
Hope it helps. Thanks,
Angel
Hi Angel,
Thank you for providing the solution.
Actually, I don't want the grid to show any data until a condition is met. And, the condition is known, once the page loads. So, I don't need to request and show the data in the Grid if the condition is not met. Hence, I need a way to block the first request that Grid makes for the data.
Hope, I've explained what I need.
if you specify a Model initially, the grid won't make a request to load the data, because the data will be sent inline with the initial request for the page:
<%= (Html.Infragistics().Grid<DataTable>(Model).ID("grid1").
(that is an example)
Let me know if this is what you have in mind.
