Based on the attached example I have two questions.
1. Why when going into edit mode does the combo editor display the valueKey vs the textKey?
2. Why does the combo box appear but not display any of the select options?
Thanks!
Hello Chad ,
I’m just following up to see if you’ve been able to resolve your issue. If you have any questions or concerns or if you need further assistance please let me know.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
looks like in your column settings you have 'options' like it is text instead of without the quotes so it would be your variable.
In order for the grid to display your text value instead of the value:
You need to set up a list with your text and values and use a formatter for the column to get the text for that value.
Example:
var lookupJobTechNameList = {};
load the list:
$.each(data.JobTechNameList, function (i, item) {
lookupJobTechNameList[item["Value"]] = item["Text"];
in your grid setup:
columns: [
{ headerText: "Name", key: "ContactID", dataType: "string", formatter: lookupJobTechName },
in your column settings for the Updating feature:
columnSettings: [{
columnKey:"ContactID",
editorType:'combo',
required:true,
editorOptions: {
dataSource: data.JobTechNameList,
textKey:'Text',
valueKey:'Value',
enableClearButton:true,
nullText:"<--Enter-->",
filteringType:"local",
renderMatchItems:"multi",
filteringCondition:"contains",
autoComplete:false,
caseSensitive:false
Then in your formatter:
function lookupJobTechName(x) {
return lookupJobTechNameList[x];
