3790
latest download causes errors in setCellValue
See the following
my column name is _ so "_"  The getCellText command returns the text so we know there is no issues reading from a table at this location. Then the setCellValue command thinks the row was deleted and its clearly not. The code is halted at that point.
alert( this.gridIDMap.getCellText( rows, "_") ); //returns the text as it shows on th etable
alert( this.igGridUpdating.setCellValue( rows, "_", "test" ) );// Error: In order to support update operations after a row was deleted, application should define "primaryKey" in options of igGrid.
alert( 1 );// does nto make it to this point
setting primaryKey to "_" gives me can not convert to null opbject
also get this error on edit cell.
so I found a hack
 this.gridIDMap.cellAt( 0, rows ).innerHTML = ...
but this does not fix the edit mode
