Seem in downloading the latest trial code the combo box does not display right.
Below displays a drop down with the name as the nullText but no items appear. When I press the down arrow a grey line appears.
function menue( name, item1, item2, item3, item4, item5, item6, item7, item8, item9, item10) { makeWindow( inWindowDiv, inX, inY, 1, 1 )//set up windows size bar and position. $( function () { var file = [ { "item": item1 }, { "item": item2 }, { "item": item3 }, { "item": item4 }, { "item": item5 }, { "item": item6 }, { "item": item7 } ]; $.ig.loader( function () { inIUDiv.igCombo( { dataSource: file, virtualization: true, nullText: name, textKey: "item", valueKey: "item", width: "200px", autoComplete: true } ); } ); } ); };
Hi seang,
Can you check for some errors which have been thrown into the browser console?
wow, sorry but looks like its now fixed? IO have been working on thing unrelated and in checking on this for you I see its corrected. These this happen, look like it must not have been infragistics code.
