Hi there,
I'm using latest release 12.2.20122.2176 and doing multiple row selection with check boxes, it's working fine.
I've a requirement to update another row and also select it. Problem is that when I try to click any cell of unselected row, it uncheck the check boxes of all selected rows.
And I also found that same thing on your example on below link:
http://ko.infragistics.com/products/jquery/sample/grid/row-selectors-with-checkboxes
Please advise any help, its very urgent for us.
Jasdeep
I have tried above solution to get default behavior. But after adding this solution select page checkbox located on Header stopped working.
I am using paging also. Please help me out.
Please check fiddle.
http://jsfiddle.net/4y5f1brt/
Hardik
Hello Jasdeep,
Thank you for your reply. Glad to help.
Please feel free to contact me if you have any further questions regarding this matter.
Thanks, It's working as expected with your code help.
What you are describing seems to be the default behavior of igGrid as clicking on an unselected row's cells would unselect the selected rows and also automatically uncheck their checkboxes. If you are using row selection and wish to ensure that rows would not be unselected when clicking on unselected row's cells (or that when clicking on an already selected row the other currently selected rows won't be unselected) you may use something similar to:
features: [ { name: "RowSelectors", enableCheckBoxes: true }, { name: "Selection", mode: "row", multipleSelection: true, rowSelectionChanging: function(evt, ui) { var rowIndex = ui.row.index; var selectedRows = ui.selectedRows; for(i=0; i <selectedRows.length; i++) { if(selectedRows[i].index === rowIndex) { evt.preventDefault(); return; } } evt.preventDefault(); $("#rowSelectorsGrid").igGridSelection("selectRow", rowIndex); debugger; } } ]
Please let me know if this helps.
