When in cell edit mode, if we hook the editCellEnding event and cancel it due to invalid information and set the keepEditing flag to true, the invalid cell's contents can end up displayed over the top of the next cell if the user left the invalid cell by tabbing.
We have tracked this issue down to the premature removal of the edit class in infragistics.ui.grid.updating.js, method _endEdit.
In this method, the editingCell css is removed as soon as the validators are checked, but this action does not take into account the fact the the editCellEnding event may be cancelled.
The solution is to only remove the class after editCellEnding has successfully completed:
// cell editing if (!vals) { if (e && oldUpdate && !_filter(editor, 'validate')) { if (!stop) { _stop(stop = e); } // scroll to and set focus to editor this._scrollTo(td, editor, 1); return 1; } // Don't remove the class until we are sure editCellEnding succeeds //td.removeClass(this.css.editingCell); }
// prevent double processing of same event (user showed alert!) this._skip = 1; // 1-hide buttons this._doButtons(1); val = _filter(editor, 'getValue'); arg = this._evtArg(td, editor, val); arg.update = !!update; arg.oldValue = editor._oldCellVal; if (!vals) { arg.keepEditing = false; } if (!this._fire('editCellEnding', eArg, arg)) { arg.value = editor._oldCellVal; } if (oldUpdate && !vals && e && arg.keepEditing) { _stop(e); // scroll to and set focus to editor this._scrollTo(td, editor, 1); delete this._skip; return 1; } // Added next 3 to support cancellation and continued editing of cell when editCellEnding fails. if (!vals) { td.removeClass(this.css.editingCell); }
Hello Karl,
Please do not hesitate to contact us if you are still experiencing any issues with this scenario.
Hello Karl ,
Could you let me know which version of our controls you’re currently using?
I’ve tested this with version 13.1: 13.1.20131.2039 and I was not able to reproduce this.
If it’s browser specific please let me know which browser it reproduces in and its exact version.
I’m also attaching the sample I used to test this. Let me know if I’m missing anything from your scenario.
Best Regards,
Maya Kirova
Developer Support Engineer II
Infragistics, Inc.
