300
Strange issue with column resizing in IE10 with another window open
When resizing a column using the igGridResizing with an overlapping window, the whole window which contains the grid is sometimes set behind another window that overlaps with it. This is best replicated after using window.open() on a page. I have attached a sample of this happening, just replace the js/css references. This only appears to happen on IE10.
GridColumnResizeIE10.zip
  • 29417
    Hello Bertm13 ,
    I was able to reproduce you issue in IE10. I’ve opened a new private case regarding this with number : CAS-119900-B4J1L1.
    I’ll log the issue as a development issue that will be reviewed by our development team.
    We can continue communication trough the case.
    Best Regards,
    Maya Kirova
    Developer Support Engineer II
    Infragistics, Inc.
