25
igTree add node dynamically
I am using igtree to add tree node dynamically.But i am not able to see the text of the newly created treenode.
This is my reference http://ko.infragistics.com/products/jquery/sample/tree/add-remove-node-api
To create tree i am using a model class
//modal class
public string Name { get; set; }
        public float Value { get; set; }
        public virtual List TreeNodes { get; set; }
//tree
 @(Html.
                    Infragistics().
                    Tree().
                    ID("MVCBoundTree").
                    SingleBranchExpand(true).
                    Bindings( bindings => {
                        bindings.
                        TextKey("Name").
                        ValueKey("Value").
                        ChildDataProperty("TreeNodes");
                    DataSource(Model).
                    DataBind().
                    Render()
//adding node dynamically
$("#btnLevelCategory").click(function () {
            var selectedNode = $("#MVCBoundTree").igTree("selectedNode").element;
            var selectedPath = $("#MVCBoundTree").igTree("selectedNode").path;
            if (selectedNode != null) {
                // Create new node
                var newNode = {
                    Text: "My New Node",
                    Value: Math.floor(Math.random() * 1001)
                // Add node to Tree
                $("#MVCBoundTree").igTree("addNode", newNode, selectedNode);
                // and expand node
                $("#MVCBoundTree").igTree("expand", selectedNode);
I can see a new item added , but the text is always coming as empty.Why is the text of new node coming as empty?
Balu
Parents
  • 25
    Is this a bug in infragistics?
    I read in the forum that Infragistics tree doesn't allow dynamic addition of tree.
    Any update on this post?
    Balu
Reply Children
No Data
