I'm trying out the ignite ui controls. When copy pasting the nestedsplitter.html example from your site, i get the following javascript error when i try to select a node in the tree:
Uncaught Error: cannot call methods on igGrid prior to initialization; attempted to call method 'destroy'
I have tried with versions jquery >= 1.9. The version of the ignite ui im using is 13.1.20131.2143
I have exactly the same problem. When I catch the rendered event and try to call igGridUpdating(X), I'm always getting "cannot call methods on igGridFiltering prior to initialization; attempted to call method X"
Example:
rendered: function(evt, ui) { var editing = grid.igGridUpdating("isEditing"); },
When I place a breakpoint at "var editing", I'm hitting the breakpoint and I'm always getting "Uncaught Error: cannot call methods on igGridUpdating prior to initialization; attempted to call method 'isEditing'"
dataSource is JSON data and showing properly in the grid. I can perfectly edit, delete, save,... But every call on igGridUpdating is failing.
Hey Edward,
All of the IgniteUI widgets have the rendered event, you can bind to it to make sure that the widget is loaded and rendered, before interacting with it.
hey is this possible to call method after infragistic load
Peter,
I tried as you suggested, but I am still receiving the "prior to initialization" error?
<script>function lstSourceCharacteristicValuesSearch() { var x = document.getElementById("sbSourceCharacteristicValues").value; if($("#lstSourceCharacteristicValues_table").data("igGrid")!=null) { $("#lstSourceCharacteristicValues_table").igGridFiltering("destroy"); $("#lstSourceCharacteristicValues_table").igGridFiltering("filter", ([{fieldName: "lookup_display", expr: x, cond: "contains"}])); }}</script><div id="sbSourceCharacteristicValueslstSourceCharacteristicValues" style="position:abosolute; left:50px; top:625px; width:400px; height:48px; z-index:4;" class="SearchBox"><input type="text" id="sbSourceCharacteristicValues" onkeyup="lstSourceCharacteristicValuesSearch()"></div></div></div>
I am using filter using Javascript and getting following error:
Error: "cannot call methods on igGridFiltering prior to initialization; attempted to call method 'filter'"
1) grid already refreshed with data (loaded)
2) applying the filter programmatically
function applyFilter() {
var component = $("#Component").val(); var attKey = $("#AttributeKey").val(); var attValue = $("#AttributeValue").val();
debugger; $("#grid").igGridFiltering('filter', ([ {fieldName: "ComponentDesc", expr: component, cond: "contains"}, {fieldName: "AttributeDesc", expr: attKey, cond: "contains"}, {fieldName: "CategoryDesc", expr: attValue, cond: "contains"} ])); }
help is much appreciated.
