I have 4 tiles on my page, once I maximze one tile, remaining 3 tiles moves on right side of the page. Is it possible to move those tiles at the bottom of the maximized tile?
Hi there,
I will answer the second question first. I assume that you are initializing the Tile Manager on existing markup. You can have different controls in the containers and they should be initializing just fine. If you are databinding the control then you can add the controls to the created markup or initialize them on it. About the first question we would need to play with it in order to give you a sample of how to do this. The control was CTP with 13.1 but we're about to release an RTM version with 13.2 with A LOT of new functionality. The 13.1 version is a preview and it's very limited in terms of out of the box functionality. I will follow up with more info on your first question.
Thank you for using the Infragistics forums!
Can someone reply if this is even possible? So I can think other options.
Even though I haven't received answer to the question on this post, I have another question on top of this, is it possible to have different controls in all 4 tiles? I hope to get answer soon.
