Cell is not updated when changing the property value of a new object added into the model for an igGrid (and igHierarchicalGrid)
Here is the example: http://codepen.io/anon/pen/hHCwu
Hello Francesc,
I created the following case for you: 'CAS-125178-L9Y1W4' and will update you through it. You could see it in your account in the 'Support Activity' page.
This seems to be a bug in the KO integration which I've logged with internal ID of 152021. The next step is for a case to be created which will be linked to the internal work item.
Thank you for using Infragistics forums!
Best regards,
Stamen Stoychev
