Hi, I wanted to use igCombo with knockout control, but I don't want to use the loader file.
At the present I see the textbox and when I type I see the dropdown options, but I dont see a dropdown button with the textbox to show the dropdown options
Here are the files that I am referencing
infragistics.core.js
infragistics.lob.js
infragistics.dv.js
infragistics.datasource.knockoutjs.js
infragistics.ui.combo.knockout-extensions.js
infragistics.css
infragistics.ui.combo.css
Hello Krishna ,
I see you’re using the combined scripts. They include all the other scripts so referencing just these three:
Is enough for all of the igniteUI controls.
The css that’s missing is the infragistics.theme.css file. It contains the themed styling for all of the controls.
Make sure you also add a reference to it. You can find in the directory where you’ve installed the product. By default:
C:\Program Files (x86)\Infragistics\IgniteUI 2013.1\css\themes\infragistics
Make sure that if you add it to your project you also add the images folder which is in the same directory.
Best Regards,
Maya Kirova
Developer Support Engineer II
Infragistics, Inc.
