LS
I am searching for an example about a simple drag and drop in a container. I want to drag a checkmark item onto a container (which holds a svg) and read the coordinates of the drop. In jquery mobile I have problems and want to check if igniteUI can do this task.
Can you show an example of normal drag and drop ? (Without a tree and other cool features)
Arthur
We provide you a straightforward design for your eBay listings. This not only adds a professional look to your online listings, but it helps spread the word of your brand as a whole. You should be an eBay sellers wish to design your own eBay template. Phoenix team provides some of the best eBay templates available.
Hi Arthur,
The jQuery UI framework provides draggable and droppable components. You can see examples of those:
http://jqueryui.com/draggable/
http://jqueryui.com/droppable/
The Ignite UI product is build on top of the jQuery UI framework and integrates perfectly with it.
Thank you for using the Infragistics forums!
