2048
New licensed version 2013.1.2217 - Big Problem
Last week I bought IgniteUI license and I downloaded 2013.1 version (2013.1.2217). I replaced Infragistics.Web.Mvc reference, all ig .css and all ig .js in my project, substituting them with the ones just downloaded from Account/KeysAndDownloads products dashboard.
Bad work: ig datepicker started to not work. When I click on the control I am able to see the datepicker, but after a date selection control is unusable, like if I have one possibility: "select one date because you have one shot". After selection I have to click out of the control, re-click on the control, re-click out of the control and then I am able to click on the control and see the datepicker. Of course if I select a date I have to redo all the operations...boring and unusable!!!
If I use IE9 I am less lcuky, because I can see the datepciker disabled after I select a date...
I did not change anything else, so I am using:
- jQuery 1.9.1
- jQueryUI 1.10.2
Do you have some ideas? I also noticed a bad beahvior on IE9 for igGrid...on IE10 all right, but on IE9 footer is out of layout (all paging fetures aligned to the left). I checked loaded CSS and I can see igGrid css missing...I forced it into IgLoader resources and of course it works, but I don't understand why now I have to explain igGrid into the resources while it was an automatic loading with igLoader before...
I am a little confused about this update...of course it is not the fact IgniteUI is now licensed, but the version to which I upgraded it.
I passed from 2013.1.2039 to 2013.1.2217 (css and js files passed from April 19 2013 to August 15 2013).
This is what I tried to do: with the last dll (Infragistics.Web.Mvc version 4.13.1.2217) I replaced infragistics.ui.editors.js and...surprised: datepicker started to work again...
If I come back to the previous version everything works, also grid footer...
Could you help me?
Flavio M.
