Infrafistics Support,
I'm looking for this(http://demos.kendoui.com/web/grid/detailtemplate.html.) data format using Ignite UI Grid. Is it possible?
Thanks, Peter
Hello Peter,
A sample illustrating the use of a row template in igGrid (and igHierarhchicalGrid) may be found at:
http://igniteui.com/grid/row-template
The hierarchical grid however, currently does not support the templating of whole child layouts to allow organizing the layout in a tabular mode. You can suggest this functionality as a new product idea at <http://ideas.infragistics.com>.
There are many benefits to submitting a product idea:
- Direct communication with our product management team regarding your product idea.
- Notifications whenever new information regarding your idea becomes available.
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
- Allow you to shape the future of our products by requesting new controls and products altogether.
- You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Thank you for contacting Infragistics.
Additional information: the data in the row template will be in tab format using unordered lists. The data for each tab will come from an AJAX calls
This forum post http://ko.infragistics.com/community/forums/t/72835.aspx mentions using a row template. Any samples you have would be great.
