3790
Primary key corrupts grid when using check boxes.
In my attachment on the left is the result with not using a primaryKey ( this is desired ). If I use a primaryKey I get what you see on the right.
The header column name for the first column you see is an under score. It does not matter what I set the primaryKey to both cause this strange result.
my data is as follows: [{"_":"Adaptive Control Switch","Value":"1"},{"_":"Adaptive Max ACT to Allow Adaptive Learning","Value":"180"},{"_":"Adaptive Max ECT to Allow Adaptive Learning","Value":"230"},{"_":"Adaptive Min ACT to Allow Adaptive Learning","Value":"-20"},{"_":"Adaptive Min ECT to Allow Adaptive Learning","Value":"150"},{"_":"ADEFTR","Value":"0.000225"},{"_":"Adpative Correction Max Allowed Learned","Value":"0.75"},{"_":"Adpative Correction Min Allowed Learned","Value":"0.25"},{"_":"Amplitude Multiplier for Adaptive","Value":"0.52"},{"_":"Dead Band to Not Adapt","Value":"0"},{"_":"Green Engine Adaptive Gain","Value":"1"},{"_":"Load to Define Decel for Adaptive","Value":"0.14"},{"_":"Max TP to Allow Learning","Value":"1023"},{"_":"Min ECT Temp for Adaptive","Value":"150"},{"_":"Min Load to Allow Learning","Value":"0.1"},{"_":"Number Of Warm Up Counters for Fast Adaptive","Value":"5"},{"_":"RPM to Define Decel for Adaptive","Value":"1000"},{"_":"Switch to Shut Off Kam Fuel Reset","Value":"0"},{"_":"Unique Decel Kam Cell Switch","Value":"1"},{"_":"Warm Up Temp for Adaptive After Start","Value":"120"}]
my column are : [{"headerText":"_","key":"_","dataType":"string"},{"headerText":"Value","key":"Value","dataType":"string"}]
This is how I do my checkboxes in my rows loop
 this.gridIDMap.cellAt( 0, rows ).innerHTML = "<input name = 'check" + rows + " align='left' type='checkbox'>" + this.gridIDMap.getCellText( rows, _spaceChar )
