2585
Binding JSON Datasource with razor
Is there a special way to bind a JSON Datasource to the TileManager with Razor? We are trying the below and receiving an error.
            IList<Person> list = new List<Person>();
            list.Add( new Person(){Name="MDL"});
            return HtmlHelperExtensions.Infragistics(helper)
                .TileManager()
                .ID("dashboard")
                .DataSourceType("JSON")
                .DataSource(JsonConvert.SerializeObject(list))
                .Render();
Error: Cannot determine the data source type. Please specify if it is JSON or XML data.
  • 540
    Suggested Answer
    Hello Tammy,
    As we have released the RTM version of the Tile Manager the content template property was removed.
    Each tile now has two states - maximized and minimized and they have separate templates.
    To databind to a Datasource you can do as Nikolay showed in his example, just change the .ContentTemplate().
    Example:
    @(Html.Infragistics().TileManager()
        .ID("dashboard1")
        .DataSource(list.AsQueryable())
        .MinimizedState("<h3>${Name} minimized content</h3>")
        .MaximizedState("<h3>${Name} maximized content</h3>")
        .DataBind()
        .Render()
  • 37874
    Hi Tammy,
    I tested your code and I would suggest you to modify it as follows:
    Code Snippet
    1. @(Html.Infragistics().TileManager()
    2.  .ID("dashboard1")
    3.  .DataSource(list.AsQueryable())
    4.  .ContentTemplate("<h3>${Name}</h3>")
    5.  .DataBind()
    6.  .Render()
    7.  )
    Now it should be working correctly.
    Let me know if you have any other questions.
