45
Paging/virtualization render event
I use a virtualized grid and bind the rendered and iggridvirtualrecordsrender to make some manipulation of the cells.
The problem I have, is that if I use pagination, iggridvirtualrecordsrender is fired correctly and I see my modifications while debugging, but just after, data is loaded again in the grid and there is no more event firing.
Furthermore event iggridvirtualrecordsrender fire 2 times.
Any suggestion will be greatly appreciated!
Parents
  • 23953
    Hello Jeff,
    I logged an internal bug with number: 159020 so that we can investigate why there are 2 consecutive iggridvirtualrecordsrender events firing. However I'm not sure which event is not firing anymore? If it is the rendered event - this is expected, because this event fires only once when the grid is first created.
    Hope this helps,
    Martin Pavlov
    Infragistics, Inc.
Reply Children
No Data
