For some reason drag and drop is not working in IE11. I cannot drag measures for example into the values space, the drag action shows and then it disappears when I try to drop it. Works fine in chrome. I tried it in your samples section as well, and it doesn't work their either.
Is this a known issue?
thx
Hello Rob,
If you are still in need of assistance please do not hesitate to contact me.
I tested this sample with Windows 8.1 and IE 11. For my test I am using version 11.0.9600.16384 of Internet Explorer 11 and everything works as expected. I am dragging Measure to the Measure section and I drop it there. While dragging the circle, with the line, is showed over the areas where dropping is not allowed by design such as the Column section but when I reach the Measures section I am smoothly dropping it there.
Could you please try downloading the mentioned version of Internet Explorer( version 11.0.9600.16384) and try running the sample from our web site( http://igniteui.com/pivot-grid/overview ). Please let me know what is the result of your test with this mentioned version of IE 11.
Feel free to contact me if you have any additional questions regarding this matter.
Hello some more information..
I tried this sample http://www.igniteui.com/pivot-grid/overview and the one you mentioned in your pervious post, neither allows drag and drop in my ie 11. i'm on windows 8.1 with ie 11.0.9600.16476
When trying to drag a measure from the tree into the measures section, it shows circle wit the line through it while dragging, and then when I drop it onto the measures section it disappears.
thx,
rob
I tested the sample project from our web site - Binding Pivot Grid to Xmla Data Source (http://igniteui.com/pivot-grid/binding-to-xmla-data-source) with IE11 and everything works as expected on my side. I made a video illustrating the behavior of the grid and I am attaching it for your reference.
Please make sure that you are trying to drop the Measures in an area when dropping is allowed. For instance on the Drop Data Items Here area of the Pivot Grid.
If you are still experiencing the issue could you please provide me some additional details regarding your scenario. For example which version of Internet Explorer are you using, is there any exception being thrown in the browser.
I hope you find this information helpful.
Please do not hesitate to contact me if you have any additional questions regarding this matter.
