I created a test asp.net web page using your WenUpload control to load files to server by VS 2010 on Wondows 7 following your instruction on http://ko.infragistics.com/products/aspnet/sample/web-upload/multiple-upload. After updaing reference to jquery-1.8.3.min.js and jquery-ui.min.js (1.8.11), everything looks working from web page - a file added, uploaded to server but I check physical application folder /Uploads, no files are over there. How do I solve this issue? Thanks in advance!
PS: Attached file includes aspx, apx.cs and webconfig files for reference.
Hi Pelta,
I studied this sample and am trying to revise the codes in my project. If I have a problem I will consult you for help.
Thanks a lot!
Yao
Hello Yao,
In this case you may be interested in using the save as stream capabilities of the WebUpload:
http://help.infragistics.com/doc/ASPNET/2013.2/CLR4.0/?page=WebUpload_Saving_Files_as_Stream.html
An alternative approach for saving files in a database would be to use a temporaray local copy of the uploaded documents prior to pushing them to the DB.
Hope this helps. Please feel free to contact me if you have any questions.
Hi Petar,
It is perfect working for the WebUpload to upload multiple files to a default file folder \Uploads. Now I try to upload the files and save them to SQL database. Could you give me the idea to the update, usually how to get the file content through stream?
Thanks for your help!
Petar,
I have one more issue when working on my application that I set the WebUpload invisible by its property Visible=false by default within an UpdatePanel. Based on user's selection on radio Button list, one selection needs its showing up by setting WebUpload1.Visible = true in the radio Button event SelectedIndexChanged. The program works without errors but the WebUpload control doesn't show up. Please advice.
Thanks!
