140
igGrid Combox Box Column losing value
I am losing the selected value of my combo box column in my IGNITE UI Grid when the row enters Edit mode.
All of the data loads correctly initially, but when I double click on my row, the combo box column is cleared out.
I am setting up this column via the code below:
column.For(x => x.Size).HeaderText("Size").Width("10%").FormatterFunction("lookupBarSize");
cs.ColumnSetting().ColumnKey("Size").Required(true).EditorType(ColumnEditorType.Combo).ComboEditorOptions(co => co.RenderMatchItemsCondition(ComboRenderMatchItemsCondition.StartsWith).FilteringType(ComboFilteringType.Local).AutoComplete(true).DataSource(ViewBag.BarSizes).ValueKey("BarSzKey").TextKey("BarSzDesc"));
Here is my formatter function:
var sizeList = @Html.Raw(Json.Encode(ViewBag.BarSizes))
function lookupBarSize(val) {
var i, size;
for (i = 0; i < sizeList.length; i++) {
size = sizeList[i];
if (size.BarSzKey == $.trim(val)) {
val = size.BarSzDesc;
return val;
The ViewBag data is set in my Index Action in the Controller
