http://ko.infragistics.com/community/blogs/mihail_mateev/archive/2013/05/17/how-to-integrate-ignite-ui-pivot-grid-in-asp-net-mvc-applications.aspx?goback=%2Egde_100943_member_241888249#%21
I follow this example,it is successful。now i want to show multi-level dimension。
fidder info:
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/"><soap:Body><soap:Fault xmlns="http://schemas.xmlsoap.org/soap/envelope/"><faultcode>XMLAnalysisError.0xc10e0002</faultcode><faultstring>Analyzer: “OPTIONS”Syntax Error。</faultstring><detail><Error ErrorCode="3238920194" Description="Analyzer: “OPTIONS”Syntax Error。" Source="Unknown" HelpFile=""/></detail></soap:Fault></soap:Body></soap:Envelope>
my olap source it's right in excel 2010
thank u so much
Hello ma shifei,
Thank you for your interest in the igPivotGrid !
A detailed guide on configuring the dimensions and other metadata attributes of an igOlapFlatDataSource may be found in our documentation at:
http://help.infragistics.com/doc/jQuery/2013.2/CLR4.0/?page=igOlapFlatDataSource_Defining_Metadata.html
Hope this helps. Please do not hesitate to contact me with any questions.
