I using [igDoughnutChart][1] for my web-page, I want a graph which shows the following hierarchy - source of attack (inside) - login abuse - dos - spyware - worm - outside attackers - spying - social attacks The current object array looks like (also [demo][2]) var data = [ { "attacksource": 43, "attacktype": 60, "AT":"DoS","Label": "iNISDE" }, { "attacksource": 29, "attacktype": 40, "AT":"login abuse","Label": "outside" } ];**I want to change this to do following:-** (also shown above)Where I have a parent and child values in 2d array so above code is to transform as var data = [ [{"attacksource": 43,"Label":"Inside"}], [ {"attacktype": 13,"Label":"dos"}, {"attacktype": 13,"Label":"virus"}... ] ];I'm not sure If I have initialized / assigned 2d using **objects** correctly.I appreciate If someone can look at the code, and let me know if I'm doing this right.**UPDATE**The jsbin example is just something to illustrate my requirements for the new code. For e.g <code>"Label":"virus"</code> is currently hardcoded, in real code (which I cannot do on jsbin) is I will get the values from DB. **[VISUAL EXAMPLE][3]** [1]: http://help.infragistics.com/jQuery/2013.1/ui.igdoughnutchart [2]: http://jsbin.com/oXuMAzU/4/edit [3]: http://lh6.ggpht.com/-WsYb0mzuKs0/Umm4pmcykTI/AAAAAAAARoQ/I4NLhJ2whng/s1600-h/image9.png
I hope I answered your question. Please feel free to reach out to me if you have any follow up questions.
Thank you,
Malav Patel
Thank you for contacting Infragistics and I apologize for the delay caused in answering this question. I see this questions was posed on stackoverflow and was answered there. At this point, I assume the issue is solved. For reference, the stackoverflow page can be found under http://stackoverflow.com/questions/21486363/declaration-2d-array-containing-multiple-objects-for-graph-plugin.
