898
Can't get igUpload working
Hi, I'm working on a cshtml Project, using Jquery and JavaScript.
I can't get igUpload working. Seams that everything works fine on client side. But I never reach the ashx file.
This is my Setup
web.config for IIS7
<modules runAllManagedModulesForAllRequests="true">       <add name="IGUploadModule" type="Infragistics.Web.Mvc.UploadModule"                                  preCondition="managedHandler" />     </modules>
and handler
<add name="IGUploadStatusHandler" path="../webservice/fcus.ashx" verb="*"                type="Infragistics.Web.Mvc.UploadStatusHandler" preCondition="integratedMode" />
Client
$(function () {
             $("#igUpload").igUpload({
                 mode: 'single',
                 autostartupload: true,
                 allowedExtensions: ["gif", "jpg", "png"],
                  progressUrl: currentHost + "/Webservice/fcus.ashx",
                 controlId: "serverID1",
                 onError: function (e, args) {
                     alert(args.errorMessage);
                 fileSelecting:function (e, args) {
                                         if (imageCounter >= 10) {
                         alert(findEntry("maxFile", "Step"));
                         return false;
                 fileUploaded: function (e, args) {
                    loadPictureList();
This is my ashx
<%@ WebHandler Language="C#" Class="fcus" %>
using System;
using System.Web;
using System.IO;
public class receiver : IHttpHandler {
public void ProcessRequest (HttpContext context) {
string filename = context.Request.QueryString["filename"].ToString();
using (FileStream fs = File.Create(context.Server.MapPath("~/UserImages/" + filename)))
            SaveFile(context.Request.InputStream, fs);
private void SaveFile(Stream stream, FileStream fs)
byte[] buffer = new byte[4096];
int bytesRead;
while ((bytesRead = stream.Read(buffer, 0, buffer.Length)) != 0)
            fs.Write(buffer, 0, bytesRead);
public bool IsReusable {
get {
return false;
  • 898
    Verified Answer
    after checking my configuration I found some mistakes. I solved them by reading som other Posts. Now eyerything works fine.
    Regards Manfred
  • 898
    Update:
    this is the actual upload URL. But still no sucess
    progressUrl: "/IGUploadStatusHandler.ashx",
                    uploadUrl: currentHost + "/Webservice/fcus.ashx",
