Background, need to move to IE11, my app use Ignite 2013. I get an error in IE11 with jquery.
So I tried the fiddle example to see how to do it right. It does not work in IE11 either.
http://jsfiddle.net/gh/get/jquery/1.9.1/igniteuisamples/jsfiddle-samples/tree/master/EN/HtmlSamples/grid/bind-grid-with-ko/
I have no compatibility settings. Should I? Fresh upgrade from MS.
My web app works ok as is in IE10,FF,Chrome. But I get an error from jquery with IE11. So suppose I need to find the correct match of components. If the JSFiddle example had worked I would have just downloaded the jquery and knockout js files it uses.
Please let us know how the performance improvements affected your app.
Thanks, I uninstalled and re installed IE and made sure to 'reset' all the settings. It seems to work, so I must have done something to IE11. Next step is to use this example and try to get better performance.
sorry about the abysmal part. It's likely that I am doing something wrong, I rolled back to what I had that at least worked.
I found it. The results are abysmal so far
How do I get a zip or file download with the service release?
