and also want to know that how to change the color of grid..Please help me....
Hello Mayuri,
Do you want me to consider any additional specificities of your scenario? If so, don’t hesitate to post here your requirements.
Hi
actually am still facing the header issue as you told me am doing like that but which is not the proper solution for me. my requirement is like that i want to add the alternate color bands for all the headers.
I am just following up to check if you have any further questions regarding this scenario. If so, feel free to contact me again.
thank you dimka
its working for me also
but when we change the background color to respective one it reflects but at the same time the lable of header is into the span so it look funny
<span class="ui-iggrid-headertext">Doctor name</span> then how to change the only css of this because the every header span has the same class name as class="ui-iggrid-headertext"
Have you changed the styles to correspond to your grid column id-s?
# hierarchicalGrid_DoctorName
background:blue;
# hierarchicalGrid_DoctorID
.ui-iggrid-expandheadercell {
background:blue !important;
.ui-widget-header {
background: none repeat scroll 0 0 #FF0000;
border-bottom: 1px solid #777777;
color: #FFFFFF;
font-weight: normal;
From the code you have provided they should be something like the id-s above.
I have tested this on a couple of projects and this works as expected.
