645
igDialog and Knockout js
I have a dialog with controls inside bound with Knockout. Everything works well for me except one thing: once user made some changes on dialog (like check some check boxes, type in some text) then close it, next time all the changes remain. To close the dialog, I just use this function: $("#print-dialog").igDialog("close");. Did you see this issue before and if yes, what was your solution to fix this?
FYI, my function to open the dialog follows:
function showPrintDialog(exam_id, exam_type) {
    if (print_first_time == true) {
        print_model = new printDialogViewModel(exam_id, exam_type);
        ko.applyBindings(print_model, document.getElementById('print-dialog'));
        $('#print-questions').customRadioCheck();
        $('#print-answers').customRadioCheck();
        $('#print-explanations').customRadioCheck();
        $('#print-answer-key').customRadioCheck();
        $('#print-blank-answer-sheet').customRadioCheck();
        $('#print-range-text').igTextEditor();
        $('#print-range-text').igTextEditor("option", "disabled", true);
        $('#print-exam-print-btn').igButton();
        $('#print-exam-cancel-btn').igButton();
        print_first_time = false;
    } else {
        // reinitialize the data
        print_model.Questions(true);
        print_model.Answers(true);
        print_model.Explanations(true);
        print_model.AnswerKey(false);
        print_model.BlankAnswerSheet(false);
        print_model.QuestionRangeText = ko.observable("");
    $("#print-dialog").igDialog("open");
    $(function () {
Thanks in advance.
