545
I am using infragistics igrid control when it showing me data it does not display the data of the records in the respective columns.
Now I am using infragistics igrid control when it showing me data it does not display the data of the records in the respective columns.
When I am look in to this I found that the first two columns are combining with each other.
Can you please look into this and tell me what to do.
  • 20255
     I just wanted to let the other community members know that this thread is duplicated with (http://ko.infragistics.com/community/forums/p/87171/434851.aspx#434851) and will be discussed into the following link.
     Thank you for using our product.
  • 20255
    Hello sushant zanzane,
     Thank you for using our forum!
     As I understand the data is not visualized, this may be caused by incorrect data bind or some JS error caused by code interaction. It will be highly appreciated if you provide me with isolated sample in order to investigate this behavior.
     Also what do you mean by saying "combining with each other"?
