1490
Date Picker filter can show up off grid in firefox
We have a grid with a date column. You have to scroll to the right in the grid to see this column. In firefox, if you take the following actions, the date picker filter shows up completely off the grid:
1. Have an igGrid with date column that cannot be seen initially and you have to scroll right in the grid to see the column.
2. Open in firefox and filter that column by a date that has no matches in the grid (so all records will be removed). In this instance the date picker shows up correctly on the grid.
3. Now click the filter drop down again for the same column - the date picker shows up way to the right and completely off the grid.
Please see attached for screen shots. It appears what it is doing is shifting the grid columns back to the left (I can see first column again, and the date picker is showing up where the date column is now hidden (would have to scroll to the right in the grid).
firefox date grid filter.zip
