145
igTree 2013.2: Using node content templates with knockout.
Is it possible to use node content templates in the igTree control when when using KnockoutJS data binding? When i tried to use a content template the node text was replaced with java script code instead of the property value.
Here is an example: http://jsfiddle.net/38prU/1/
The example is based on the demo from http://igniteui.com/tree/bind-tree-with-ko . The only thing i changed was to replace
textKey: 'CategoryName'
in the binding with
nodeContentTemplate: '${CategoryName}'
which should (if i understand correctly) yield the same result.
What do i have to change to make the template display correctly.
