Hi
Ignite ui 13.2
I can't figure out how to type a new line into a grid cell.
eg I am using cell edit mode nad I want to enter this:
Line 1
Line 2
Line 3
Whenever I hit the enter key it ends the edit. Same with ctrl+enter and alt+enter.
Is there a special key combination that I need to use?
I have set up a column formatter to convert new lines into tags as described here:
http://ko.infragistics.com/community/forums/p/80503/406279.aspx#406279
and it is being called for the column in question, I just can't figure out how to type them into the cell.
Graeme Hart
Hi Graeme,
Thank you for sharing your code with the community.
If you have any further questions on the matter, please let me know.
Thanks very much for the pointer. I now have it working.
For completeness, I am setting up the grid model in my controller so I have the following setting for this column:
oUpdating.ColumnSettings.Add(new ColumnUpdatingSetting() { ColumnKey = JobViewModel.COL_NOTE_NoteText, EditorType = ColumnEditorType.Text, EditorOptions="textMode:'multiline'" });
I have to press shift+enter to type a new line into a cell.
Graeme
Hello Graeme,
I would suggest you to use a text editor provider for the grid columns where you will need line breaks. Set the editor's textMode to multiline: http://help.infragistics.com/jQuery/2013.2/ui.igtexteditor#options
http://help.infragistics.com/Help/Doc/jQuery/2013.2/CLR4.0/html/igGrid_Updating.html#example_usage_of_columnsettings
Hope this helps.
