Good day,
I am having a strange situation with the upload control when using IE 9.
I upload the file data directly to a WCF service, by changing the "uploadUrl" property to my WCF REST service, that accepts a stream.
However, this method also returns a list object, but in IE 9, the data returned is trying to download a file instead of firing the "uploaded" event.
What could be causing this?
Hi Miroslav,
Thank you for the explanation and the link. I'll implement this and test it, and leave a reply regarding my results.
Eduard K.
IE9 does not implement HTML5 file API so when select file in the igUpload the file is "included" in a form and when click upload this form is submitted. So in IE9 if your service returns some data in JSON then the browser IE7-10 probably starts downloading it. So my advice is just to change a little bit your service. I have made a little research - you can check this post in StackOverflow - http://stackoverflow.com/questions/13943439/json-response-download-in-ie710. In short you should return the json as text/html since IE does not know what to do with application/json contents. I hope this will help you.
text/html
application/json
Miroslav Hristov
