4040
Recursive loop inside grid layouts hierarchy
I already wrote a post about this problem, but I don't have a solution.
Sorry to have to write a post again (see http://ko.infragistics.com/community/forums/p/86514/432978.aspx#432978)
I am trying to use igHierarchicalGrid with several levels.
As I understand one sub-grid is generated for each level.
I would like to recursivelly loop inside the list and for each "node"/grid, I would like to know if it is a leave (last level). So :
     1 - if it is not a leave I should be able to expand or collapse the level
     2 - if it is a leave I should be able to change grid options (ex : editMode)
Examples I found allow to browse first level only.
Do you have an example of code to achieve this two points ?
Thanks for your help.
Alain.
