Hi Martin,
I am using SelectionPersistence.js you provided to me.
I am enabling filtering with selection persistence.
Here is the grid code and associated events.
<script> $.ig.DataSource.prototype.settings.paging.pageIndexUrlKey = "page"</script>@(Html.Infragistics().Grid(Model.Customers.AsQueryable()).Width("400px").Height("300px").AutoGenerateColumns(false).ResponseDataKey("Records").Features(feature =>{ feature.Filtering().Type(OpType.Remote); feature.LoadOnDemand().ChunkSize(10).LoadTrigger(LoadTrigger.Button);}).DataSourceUrl(Url.Action("GetAllC")).DataBind().Render())
Here are event I attached
var sp; $.ig.DataSource.prototype.settings.paging.pageIndexUrlKey = "page"; $(document).on("iggridrendered", "#myIGrid", function rendered(evt, ui) { sp = SelectionPersistence(ui.owner); sp.enableFiltering(); });
Issue #1: With above code persistence works fine. But I error in below deselecting scenario
1. Select a row.
2. Filter(remote)--enter some characters in filter text box for any column
3. Remove text from filter text box
4. Try to deselect a selected record.
5. I get the error when deselection row at row index 1:
Unhandled exception at line 366, column 12789 in http://cdn-na.infragistics.com/jquery/20132/latest/js/infragistics.lob.js
0x800a138f - Microsoft JScript runtime error: Unable to set value of the property '1': object is null or undefined.
6. I do not get this error when I user selection with sorting. It is coming only with filtering.
7. I used IE 9(standard mode)
Issue 2: When I enable LoadOnDemand for grid, and do below operations, I see that some issues mentioned below
1. I have chunk size as 10
2. I select record in 2nd row and 3rd row
3. I filter grid for record which is not in 1st chunk. Grid bring data remotely, I select it which happened to be record 11 and removes text from filter.
4. Again, 1st 10 records are displayed with 2nd and 3rd row selected.
5. Now I press LoadOnDemand button at the bottom of the grid.
6. Row 11 is not selected. (How to make sure that on loadOnDemand, selection persistence works).
I hope I am clear now.
I thankful for your valuable inputs.
Rajesh
Hello Martin,
I want to thank you for the fix you provided. Both issues I raised are fixed.
Thank you very much,
Rajesh Varade
Hello Rajesh,
I was able to reproduce your Issue 1 after I read your post here: https://ko.infragistics.com/community/forums/f/ignite-ui-for-javascript/74989/iggridselection-selectedrows/437781#437781
The issue comes from the igGridRowSelectors feature which was not present in this thread sample. I've added a fix for this in the SelectionPersistence.js file which you can find attached to this forum post.
Best regards,Martin PavlovInfragistics, Inc.
Rajesh Varade said:Issue #1: With above code persistence works fine. But I error in below deselecting scenario
I'm not able to replicate this in my sample. Can you try to replicate it with the sample which I'm attaching to this forum post.
Rajesh Varade said:Issue 2: When I enable LoadOnDemand for grid, and do below operations, I see that some issues mentioned below
I had to modify the SelectionPersistence.js file to handle the igGridLoadOnDemand.rowsRequested event. You can find the file in the same sample under the Scripts folder.
Note: The sample should run out of the box. I configured it to use NuGet package restore option, so the first time it will download all the required assemblies.
Hope this helps,Martin PavlovInfragistics, Inc.
