455
upgrade from 2013.2 from 2012.2
I have just upgraded from 2012.2. to 2013.2 ignite ui ( full product - not trial ) and have some questions.
First - the scripts don't seem to have an infragistics.js in the package. I have left it in my scripts. Is that correct?. If I take it out it gives errors.
I want to upgrade jquery - what version can I go to.
We are running mvc4, jquery 1.5.1 and jqueryui 1.8.11.
thx
  • 2355
    Verified Answer
    Hi bubblesdad,
    Thank you for posting in our forums! We separated Infragistics.js file into 3 different files: infragistics.core.js, infragistics.lob.js and infragistics.dv.js . You should replace the references with them.
    About the jQuery and jQueryUI versions - I would recommend you to use the latest (more detailed info about the latest releases here – jQuery and jQueryUI). I also recommend you to use the latest jQuery from the 1.x branch because the 2.x branch does not support older IE versions like 6,7 and 8.
    I hope this helps!
    Kind regards,
    Petko Zhekov
    Senior Software Engineer
