Dear Support Team,
is there an option, that expands all hierarchies on all dimensions by default?
best regards
Florian
Hello Florian,
I would like to make sure I understood the request correctly. Please let me know if the behavior you have in mind is similar to the following sample:
http://ko.infragistics.com/products/wpf/sample/pivot-grid/flatdatasource-xaml
Hi Vivian,
can't tell from the example. I need all dimensions to be opened by default. For the moment, I only manage to open the first dimension on both the x- and y-axis. I guess some kind of loop will be necessary to determine how many dimensions are used on each axis and then extend the code calling "expandTupleMember".
