290
igCombo's item template freezes browser in 2014.1 release
After migrating to the new version my templated combo boxes freeze upon selection.
After several hours of debugging I found out that igCombo enters into an infinite recursion call of function _replaceTextInNode.
I've modified your own example http://jsfiddle.net/gh/get/jquery/1.9.1/igniteuisamples/jsfiddle-samples/tree/master/EN/HtmlSamples/combo/templates/ into http://jsfiddle.net/mPrL7/1/ in order to replicate it. I basically removed the image and address from the template. Select an item them try reopening the combo then the browser will freeze.
I would like to reiterate that my template was working in 2013.2
My template is simply <div><span>${__parameterlocal_}</span><span>${__parameter____parameterunits_}</span><span>${__designminimum_}</span><span>${__designmaximum_}</span></div>
Please could you confirm whether it is a bug? If it is, how long should I wait for a fix?
Silverio
