2350
igGrid Row Edit Dialog forces validation on open
When using the Row Edit Dialog and adding a new row, if the first field in the dialog is Required, then the validation automatically triggers for this field when the Row Edit Dialog first loads.  I would not expect this validation to trigger without the user doing anything.  It should only trigger if the user goes to the next row without entering information.
Here is a jsfiddle for this issue:  http://jsfiddle.net/ru5Rk/3/
Just hit 'Add a New Row', you will notice that the First Name field validates right away as soon as the dialog opens.  I would not expect this to happen.  This does not occur when using the regular Row Edit (non-dialog) mode.
