I am using the 2014.1 version of Ignite UI in pure javascript, and running into issues when filtering igCombo options when itemTemplate is specified.
I have modified one of Infragistics' own examples in a fiddle here, to show you what I am seeing. Also, attached is an image showing the issue.
The itemTemplate is specified to show a dual-column dropdown, but when I type something into the combo box, the itemTemplate is improperly rendered, and I get a dual-column layout with incorrect cell values, which looks like a join of datasource values for filter searching purposes.
Please help me restore template formatting. Thanks.
Hi, Rehemann.
I'm glad to hear that your issue is resolved. Thanks again for using our products.
Best regards,
Nikolay Alipiev
Thanks for the fix. I was actually waiting for the Custom Build tool to be updated on the main Ignite UI site to be updated with the latest service release, which it was.
Much thanks for your help!
Hello, Rehemann.
The problem with duplicating item's template is fixed. Now you can download the latest service release from here, and apply the fix. If you still have problems, please write us and we will try to resolve them.
Thank you for the patience and for using our product.
Nikolay
Hello rehemann,
Is there anything else I can assist you with? Please do not hesitate to ask any further questions.
i will be waiting for the updated release.
thank you.
