1145
Row Height issues with Paging/Sorting and Virtualization
Hi
I have seen others post this same issue, so I have taken time to narrow down as much as I can the observed behaviour.
Using igniteUI 2014.1
we have a grid with the following definition:
$(element).igHierarchicalGrid({
virtualization: true,
virtualizationMode: 'continuous',
height: constants.defaultGridHeight,
width: constants.defaultGridWidth,
columns: columnSrv.Columns(),
primaryKey: 'id',
features: [
type: 'remote',
mode: 'multiple',
modalDialogHeight: constants.defaultSortingDialogHeight,
type: 'remote',
pageSize: constants.defaultGridPageSize,
pageSizeList: [50, 100, 200, 500, 1000, 2000]
columnSettings: columnSrv.columnSettings(),
columnChooserHeight: constants.defaultColumnChooserHeight,
mode: 'row',
mouseDragSelect: false,
deferredResizing: false,
allowDoubleClickToResize: true,
columnSettings: columnSrv.resizingColumnSettings(),
type: "remote",
mode: "advanced",
filterDialogContainment: "window"
autoGenerateColumns: false,
dataSource: scope.vm.dataSource,
autoGenerateLayouts: false
in the following
  • row height correct means the rows are being displayed with a height of 28px
  • row height wrong means the row height has been adjusted so that the visible rows fill the grid container. So if you have a single row in the table, that row will be the entire height of the grid.
The following is with
if I disable all features the row height is correct.
If I enable only sorting
  • the row height is initially correct.
  • if I do a sort (by clicking on a column header) row height is wrong.
  • If I do more sorts the row height returns to being correct (i.e. the row height is wrong for ONLY the first sort).
If I enable only paging
  • the row heights are wrong.
If I enable only Hiding
  • row heights are correct
If I enable only Selection
If I enable only Resizing
If I enable only Filtering
If I remove virtualization, the row height is correct regardless of features.
So the row height is being adjusted when virtualization is active and we use paging and/or sorting.
if I change the grid width/height to px/% units makes no different to this issue. Just to note, if I change height to be a % unit rather then px a different issue arises which I will document in an other post.
Regards
Aidan
